VHPD Engine Woes!
Topics relating to the series 1 Exige
Has thanked: 4 times
Been thanked: 16 times
Re: VHPD Engine Woes!
Post by jonnyfox »
Good call by Keith as well. I managed to flood mine, ran an 2 cylinders till I yanked the spark plugs out and gave them a clean.
R300
trackrod
Has thanked: 2 times
Been thanked: 2 times
Post by trackrod »
Gets engine running gradually worse while warming up or is it more of a sudden change? The ECU runs in open loop while being cold and switches to closed loop mode once the engine reaches a certain temperature (closed loop: ECU tries to control mixture and ignition by looking at the current lambda readings).
Lots of things can go wrong there (bad lambda probe, air leaks, etc.). You may think of hooking up an OBD scanner to see what the ECU is doing. Check the 'sorting VHPD drivability' thread for more details.
Klaus
winthattt
Been thanked: 3 times
Post by winthattt »
trackrod wrote:
Thu Aug 22, 2019 8:30 pm
Klaus
Klaus,
That is exactly why I asked my questions. Not sure if you have this saying in Germany, “great minds think alike, and fools seldom differ”. We are thinking the same! Keith
tlracer
Has thanked: 1 time
Post by tlracer »
OBD scanner, as Klaus recommends, should hopefully give you a steer with any errors that flag up. Also I'm wondering if, as the fault only occurs once the engine's hot, whether heat is affecting a wire ( eg. injector cable ) causing a bad connection or a break to open up?
Fonzey
Has thanked: 22 times
Been thanked: 13 times
Post by Fonzey »
S1Exige wrote:
Thu Aug 22, 2019 6:17 pm
Fonzey wrote:
Thu Aug 22, 2019 2:51 pm
Where is it in East Yorks? If you don't mind saying :thumbup:
Burton Pidsea area but it's nobody on this forum or who has any connection with Lotus.
Fair enough, thought there may have been a local specialist that had slipped under my radar :mrgreen:
S1Exige
Post by S1Exige »
winthattt wrote:
Thu Aug 22, 2019 7:42 pm
How long does it run OK for and what is the reading on the water temp when it starts to run badly? Is it really running on three (which cylinder is cutting out) or is it just running really rough. I ask the questions because it makes a difference to determining what’s wrong.
Keith
Hi Keith
I've been told once it gets to temperature, it drops down to 3 cylinders, misfires and runs like a bag of spanners..........i've not witnessed it running but they say it's also running very lumpy compared to usual...…...that's basically all that I know plus they've replaced some parts that haven't made any difference...….i'm thinking liner heights ?
The same company did the first rebuild which lasted 2wks and it was cyclinder 1 that failed (liner cracked) piston 1 was also replaced for the second rebuild.
AKA M7EXG
S1 Exige #96
340R #84
winthattt
Post by winthattt »
So it’s lumpy all the time and as it gets warm it gets worse? When they say running on three the just mean it is lumpy and is missing some firings. Does it back fire and make bangs out if the exhaust? Is that a better description, I know it’s hard to say as you are going on what they have said to you. Very different problem if it’s always rough and gets worse.
Keith
trackrod
Post by trackrod »
winthattt wrote:
Thu Aug 22, 2019 10:49 pm
... Not sure if you have this saying in Germany, “great minds think alike, and fools seldom differ”. We are thinking the same! Keith
Keith, I don't think we have that saying in Germany in full length, only half of it: 'Zwei Trottel - ein Gedanke'.
Unfortunately it corresponds to the second part of the English saying.
S1Exige
Post by S1Exige »
winthattt wrote:
Fri Aug 23, 2019 8:19 pm
Keith
They say from start up to temperature, it runs fine.............once at temperature, it drops to 3 cylinders, misfires out of the exhaust was their description and it won't pick up revs.
I'm hoping to pop down this week tofind out for myself.
Graham
AKA M7EXG
S1 Exige #96
340R #84
seriouslylotus
Been thanked: 6 times
Contact:
Post by seriouslylotus »
Cut your losses and take it to somewhere else!!!
