sorting VHPD drivability issues
Topics relating to the series 1 Exige
Evoman
Re: sorting VHPD drivability issues
Post by Evoman » Thu Jun 27, 2019 4:33 am
These Exiges seem to very sensitive to electrical system being in absolutely of the highest order - I replaced my the HT leads with a set of leads previously used on the car (both Magnecor). The spare set had been stored in a warm roof space of the house. I fitted the new leads after spraying a small dab of contact cleaner onto the ends of each lead and fitted the plastic lead divider that was in the Magnecor box - this wasn't fitted previously.
The result? Well a purring kitten of a machine. Very responsive throughout the whole rev range, a fatter feeling torque curve and a lovely bababap bababap sound cruising around 2000 rpm and ballistic everywhere above this.
I must admit I did have thoughts of selling the little crazed thoroughbred, perhaps it heard me and is now on the best of behaviour ?!
Has thanked: 2 times
Been thanked: 5 times
Post by jonnyfox » Fri Jul 12, 2019 2:58 pm
Cars running rich, it's running well but definitely rich. First thing I'm going to try is putting the cat back on, it's a bit old and came off the car as not on when I bought it. Any of you know if this is the correct one? Also is it worth changing the lambda sensor at the same time?
Vac lines shouldn't be an issue, HT leads are new. Will check both anyhow
Oh and if you can recommend a good catalytic converter that'll slot straight into standard system that would be appreciated :D
#498
trackrod
Post by trackrod » Fri Jul 12, 2019 9:10 pm
Jonny, are you running the original ECU on your Exige? If so the MAP based load calculation seems to be quite sensible to changes in the exhaust system. I fixed a small leak at the joint between the flexible section and the headers and I noticed an improvement in drivability.
Sorry, I don't know if this is right cat. The one on my car looks different but it is an aftermarket part anyway.
If you have the smallest doubt about the condition of the lambda probe I would just replace it. It is not very expensive and not worth the trouble checking the old one for faults.
Klaus
winthattt
Been thanked: 2 times
Post by winthattt » Fri Jul 12, 2019 9:21 pm
John,
The OBD port on the S1 Exige actually works, you can connect a Bluetooth adapter to it and read the lambda probe on an iPhone. If you want to, you can borrow mine. I think there are cheap Chinese ones on eBay, some even work. It’s quite useful for basic diagnostics, you can see temp, pressure and lambda changes.
If the lambda probe does fail the ecu will not detect it, as Klaus says, you just have to change it.
Keith
Evoman
Post by Evoman » Tue Jul 23, 2019 6:27 pm
I was chasing a running rich issue for ages with a supposed number of experts getting nowhere. I went with a new 2ubular exhaust cat back system on a hunch and felt justified after seeing the back box clearly had a leak and the flexi section was suspect. Best decision ever, the car is now back on form, still sensitive it seems with the mapping of the car on the standard ECU. Good luck!
Post by jonnyfox » Tue Jul 23, 2019 8:41 pm
I've gone with an EP high flow cat, will fit Thursday along with the lambda sensor. I have also fitted new air filters and double checked the hose. Vacuum hoses all look good. Exhaust, flexi and manifold are fine, checked those too. TBH most if not all that stuff are new, I'm just hoping for a little smoother running. I'm possibly being a little over sensitive, anyway can't hurt.
#498
C8LGY
Post by C8LGY » Tue Jul 23, 2019 8:50 pm
I’d be interested to see how you find the EP cat from a noise/performance point of view - threw my cat away recently as it was goosed and just running a de-cat. Ran terribly with the cat!
Post by jonnyfox » Tue Jul 23, 2019 9:04 pm
I was going to fit my old cat but it looked knackered, non starter really. TBF it runs great with a cat bypass and really I've no complaints apart from its definitely running a little rich. Lol have never ran it without so I'm fairly interested too :D
#498
C8LGY
Post by C8LGY » Wed Jul 24, 2019 8:58 pm
Yeah mine seems to run pretty good cat-less too - think the manual mentions that they make more power without a car - although definitely very rich! I’ve heard that the 190 ECU is a much richer map than the ‘legislation friendly’ 177 unit - not sure where I read that.
Post by jonnyfox » Wed Jul 24, 2019 9:21 pm
Well cat on, lambda sensor changed although the sensor I replaced was fairly new after all. I just can't recall ever buying it, but then again I've spent that much on it I'm not surprised really :D
Just need to get and try it :thumbup:
#498
