sorting VHPD drivability issues
Evoman
Reactions:
Hey Klaus, I'm replacing all the vacuum hoses and t-pieces, I wonder do you recall the bore size of the hoses?! I'm nowhere near the Lotus and would like to order them if someone has the knowledge of the correct bore size that would be great so I can get them ordered in time for getting them installed Friday, cheers! :)
deggles
Reactions:
Evoman wrote:
Tue Feb 26, 2019 4:13 pm
Pretty sure it's 4mm internal diameter, I replaced mine a while back with silicone hose from these guys:
https://www.advancedfluidsolutions.co.uk/ - Product code was BVAC-004 for black or RVAC-004 for the red stuff (cos I fancied a bit of bling to match the HT leads and catch tank hose) :D
Reactions:
You need to get some Brasso on the throttle cable elbow :D
R300
trackrod
Reactions:
If I remember right I did use 4 mm and 3 mm hose. I think I used the smaller hose for the short piece from the T-connectors to the manifold outlets. The outlets are pretty small and one of the four were even not properly fixed on my car. Another potential air leak.
I would just order both 3 mm and 4 mm hoses and see what fits best. It's not too expensive and there is nothing more annoying if you miss a cheap part while working on the car on the weekend.
deggles
Reactions:
jonnyfox wrote:
Tue Feb 26, 2019 9:08 pm
:lol: Ha ha, I thought the bay was looking quite tidy but you're right, I missed a bit :oops: :lol:
Evoman
Reactions:
Awesome chaps, thank you for the info and links :)
tlracer
Reactions:
Check the T-connectors as well when you're replacing the hose. I found a couple of mine had gone very brittle so replaced those as well whilst it was all apart.
Evoman
Reactions:
tlracer wrote:
Wed Feb 27, 2019 8:15 am
Indeed that is what prompted full replacement as i was checking the t-piece connectors one of them snapped so a full set ordered plus extra just in case!
Reactions:
deggles wrote:
Tue Feb 26, 2019 10:52 pm
:D sorry
I bought my black hose and connectors off eBay. Same for the washer bottle.
R300
Evoman
Reactions:
So by way of update I have resolved my running issues were mainly a rich running condition.
Vac lines replaced and t-pieces, coolant temperature sensor and air temperature sensor. Result, seemed to be slightly improved but in reality still very rich.
Next step was to go with a hunch and treat the car to a 2bular cat back system as on an oil service there was clearly a leak from the back box. Turned out the flexi was caput and snapped off. So new flexi welded in along with 2bular system and she runs real sweet again. Exhaust emissions I haven't tested but for sure the richness is away. So anyone struggling with a running rich issue could be what appears to be a rather minor leak from the exhaust at the flexi (I guess the backbox leak wouldn't have affected the emissions quite so much).
