Headlight cover removal
SimonE
S1Exige wrote:Heat it up with a hairdryer, find some fishing line and do a sawing motion between the lens and double sided tape..............it worked for me
I thought that you used trackdays to remove yours Graeme? :D
S1Exige
I did Simon but it was getting expensive because I couldn't always find them ;)
AKA M7EXG
S1 Exige #96
340R #84
250 GP Cup
stevegreen101
Just came across an old photo and thought it would illustrate exactly what's what on the rear entry method.
This is with the nearside wheel liner removed:
Never having taken it out - which combination of screws and wingnuts need undoing?
STEVE.E
Just the three of the wingnuts need to be removed and the whole lamp unit and bracket can be taken away from the clam. Just make a note of the position of the spacers and springs, and take a few measurements from the lamp holder to the clam to be able to put it back in a the same position to get the beam alignment correct.
Cheers Steve.
stevegreen101
:clap:
Thanks.
I wasn't sure from the photo whether that top screw went through the clam or not - clearly if it did, it would make taking the light out from the back a near impossible task!
Given they are plastic wingnuts so no recalcitrant nuts to deal with, it should be a relatively easy job once the wheel liner is off.
Thanks, Steve, and. . . Steve
