Suspension Refresh
Ive given up on the epoxy mastic. I wasn't impressed with my brush on finish and I don't have the facility or equipment to spray so I took the lazy option and sent them to be powder coated. But that's me being fussy.Si_F wrote:Do consider the epoxy mastic,as suggested. Personally, I preffer it to Por as its just less faffy to use.
You might want to consider that ARB, you'll have some lovely shiney wishbones then a rusty arb.
Today I've learnt that certain plastic bottle caps fit very nicely into the bush hole of the wishbone. I thought this was a neat way of avoiding getting paint in them, so 32 bottles of tescos cheapest bottled water later they were good to go. But I've also learnt they would melt in the painters oven.. Ah well.
This is how I've spent my week as well. I like the Zinc coat and POR clear. Anything but black, as a light colour is easier to clean me thinks. Grime and brake dust on black is hard to see from experience. Gold to match the Ohlins but then I quite like silver too, matches the chassis
R300
Personally I wouldn't use another finish on wishbones, I've got better thing to do than a million different step processes especially when the ball joint will be knackered in a few thousand well driven track miles..... The guy I use will blast, undercoat, powder coat and clear lacquer for a few ££ per item. Have a word with the powder coater the will usually give you the tape they use to mask foc. Even if not masked a small diameter lap wheel on a die grinder will clean things up....BACON wrote:Ive given up on the epoxy mastic. I wasn't impressed with my brush on finish and I don't have the facility or equipment to spray so I took the lazy option and sent them to be powder coated. But that's me being fussy.Si_F wrote:Do consider the epoxy mastic,as suggested. Personally, I preffer it to Por as its just less faffy to use.
I sprayed the epoxy mastic and it's given a slight hammered finish to the subframe which I do like (I'm no pro but kept the thinning to a minimum to achieve it as the galvanising isn't perfect).
The next set I do will either be something bright or the anthracite I have the wheels in on both cars. Gold would be good!jonnyfox wrote:This is how I've spent my week as well. I like the Zinc coat and POR clear. Anything but black, as a light colour is easier to clean me thinks. Grime and brake dust on black is hard to see from experience. Gold to match the Ohlins but then I quite like silver too, matches the chassis
If you you've a bit of room on the drive/ garage I'll happinly come over and take you through doing this. Just supply coffee and biscuits!thommo wrote:Great write up. Very detailed and pics good too. I'd have no chance of doing this myself, much as the idea appeals.
Keep up the good work.
And, as for you Mr Fox, we need your words and pics, too, please
Day 5
Cheers for the advice and messages of support.
I've managed to strip the offside tonight, 3 hours approx compared to 6 hours for the near side
Nothing much different from my write up on the near side apart from when removing the wheel arch liner some pipes and an electrical box are attached but can easily be taken off.
Here is the anti-roll bar which will be sandblasted and then given the por-15 black treatment.
I've new bushes and drop links to go on too.
