Ohlins 2 Way with 450/600lb Springs
dris
Post by dris »
For those that have these fitted can they be made (via either the bump or rebound) compliant enough for road usage as well as occasional track use?
evo_ufo
Has thanked: 23 times
Been thanked: 6 times
Re: Ohlins 2 Way with 450/600lb Springs
Post by evo_ufo »
Depends on what your expectation of 'compliant' is. I have run the GT spec 46 dampers with similar spring rates and didn't need to go full soft. But I doubt that a normal passenger would find it comfortable.
Post by C8LGY »
Can't comment on Ohlins stuff, but I found 500lb springs too stiff on the rear no matter how much I adjusted the damping. Settled on 450 lb rear/375 lb front; think that's about 50-60% stiffer than OE?
Has thanked: 5 times
Been thanked: 17 times
Post by jonnyfox »
36 spring rates need to be softer than that on an S1 if using 2 way adjustable Ohlins as an all rounder surely.
dris
Post by dris »
Cheers for the replies chaps.
I see you (jonnyfox) have a set of these, what spring rates do you use for road?
If I was able to get hold of 350/450 springs and fit them to the ohlins would revalving be required (assuming valved for 450/600) or is there enough adjustment in the bump and rebound to allow me to use on the softer springs, swapping out to the stiffer springs when taking to track?
Post by jonnyfox »
Springs shouldn't set you back too much.
Maybe worth a call to Mick Gardener, after being introduced to him by Gav, I've always found them very helpful. Actually PM Gav on here, Tarmac Terrorist (Kevlar Kid Seloc). I had what he had on his 160, 350/450. Drove beautifully. Both will help out with valving info.
evo_ufo
Post by evo_ufo »
The Lotus Sport Ohlins for S2 were 325/425, and that's a heavier car, so if looking for something for the road in and around that level seems appropriate.
Post by jonnyfox »
^ yep 325/425 not what I posted.
Post by tlracer »
I have run Ohlins on my S1 since 2006 with no problem of them being harsh or over-hard. Offhand I can't recall the spring rates, but as I recall they are the S2 set, which Lotus supplied to me direct.
