MWR Stroker kit
Topics relating to the Lotus Exige S2 (series 2)
hogarth
Contact:
Anybody fitted one of these to the n/a 2ZZ engine?
My car is on the rolling road for mapping and people say they can only get 187bhp ...isn't that just standard power?
I haven't got a clue about these things...
The MWR stroker kit engine has been built with gas flowed head, 285 Piper cams, 400 injectors and
ECU Black, together with full 2bular exhaust system etc ...
I would welcome any thoughts
matt447
187 wheel horsepower, or flywheel? I got 210 on the bench at Track-Group, from a stock bottom end, Fidanza flywheel, ACT HDSS clutch, Cosworth head gasket, ported head, super tech valves, Eibach valve springs, Crower titanium retainers, Piper Stage 2 cams, same injectors as you, radium fuel rail, full 2bular 4-2-1, EMU Black and some time on the dyno…. That would equate to 180-something wheel horsepower at a rough guess? I’d expect your stroker with similar other mods to be more? But maybe less revvy? Mine comes alive at the top end…
matt447
Which stroker kit is it? From memory, they do different compression ratio kits?
hogarth
Contact:
Its the 12 to 1 compression kit, bought February last year
matt447
12:1 compression and the same cams as me, you really should be on for more HP than me… without question, surely?
matt447
What does the curve look like? Mine picks up hugely towards the higher revs - it keeps going up and up towards the redline. Perhaps the stroker kit affects the shape of the curve and you aren’t getting the same high rpm gains as me? And did you establish if they were talking about flywheel or wheel horsepower?
hogarth
Contact:
Apparently it was 187 at the flywheel? The whole engine was balanced and also had a lightweight flywheel fitted, so the mappers are baffled
as they expected a lot more?
This could have been a big waste of money on my part. ...aaaargh!
hogarth
Contact:
I had dropped the car off two weeks ago to leave it with them, so I haven't actually been back there and seen any data, not that I would understand a 'curve' anyway I'm afraid .... so I'm just being relayed technical information!
matt447
There has to be something going on… that just doesn’t sound right… have they checked compression on all cylinders? I think you need someone more qualified to give you an answer, but my feelings are: No, you’ve not wasted all that money, but yes there is something amiss and it just needs finding and sorting out…
Fingers-crossed for you mate!
matt447
For what it’s worth, yours should almost certainly be coming in at a minimum of what mine is achieving - and I’m only saying that because I’m apparently limited by inlet and throttle body, which I’m assuming are the same as yours still…
