Dash on , but car wont start.
Topics specific to owners of the series 2 Exige
andybond
Reactions:
Has thanked: 37 times
Been thanked: 31 times
Contact:
Re: Dash on , but car wont start.
Post by andybond »
Noooooo. Don’t cloud things. I was happy with the charger placebo!
andybond
Reactions:
Contact:
Post by andybond »
Ok , so its just got stranger.
Car started fine. However, it wouldnt switch off. Put the key back of the "off" position and it carried on. Sounded a bit erratic , but carried on. Twist back to "on" - not start and it idled away happily.
Kill the engine by putting it to off and then disco the +ive terminal on the battery
ade
Reactions:
Been thanked: 10 times
Post by ade »
Sounds like a relay pack misbehaving wont turn on, then won't turn off
andybond
Reactions:
Contact:
Post by andybond »
ade wrote:
Thu Jan 31, 2019 2:11 pm
Interesting.
Any ideas which one / where to look / wack / set fire to ?
ade
Reactions:
Post by ade »
Sorry no :(
andybond
Reactions:
Contact:
Post by andybond »
No worries. At least I have an idea that its not me going mad.
When I came to restarting it , I couldnt get the damn thing restarted.
Found a work around.
Key in ignition , pressed the immo button to arm it . Twisted key , it squarked.
Turned it off.
Car started ..
winthattt
Reactions:
Been thanked: 3 times
Post by winthattt »
andybond wrote:
Thu Jan 31, 2019 11:26 am
Smug mode on
Told you it was not the charger.
Smug mode off
However, how have you connected the trickle charger? If it’s via the lighter socket and it was powered on you may not be able to stop the engine.
andybond
Reactions:
Contact:
Post by andybond »
Connected directly to the battery via fly leads.
Turned off and not connected when starting the car.
tlracer
Reactions:
Has thanked: 1 time
Been thanked: 2 times
Post by tlracer »
winthattt wrote:
Thu Jan 31, 2019 6:04 pm
Don't think anyone said is was the charger at fault? :?
My initial thought was that it was one of the immobiliser relays (like you I've had immobiliser issues) not operating correctly which would prevent starting, but it could equally be another relay as ade suggested. MFRU faulty?
winthattt
Reactions:
Post by winthattt »
I tend to agree, dodgy relay, connection, earth etc. Don’t understand why it would not stop.
