Dash on , but car wont start.
Topics relating to the Lotus Exige S2 (series 2)
andybond
Site Admin
Reactions:
Contact:
Noted.
Will follow your recommended advice
tlracer
Reactions:
Do report back :)
We see a lot of chargers (my company works on portable lab equipment) where the output voltage take a long time to die-off after they've been switched off from the mains. This isn't a fault, but I'm wondering if leaving your powered-down charger connected for a while might allow any residual to decay.
Thinking out loud on that one, I wonder if there is a fail-safe somewhere that is designed to prevent starting the car whilst a charger is attached? That would make sense in a way, so as not to overload the charger with a massive current draw. If there's a residual voltage it may be keeping that 'live', hence the car won't start just after disconnecting the charger.
But as I say, that's just 'thinking out loud'...
andybond
Site Admin
Reactions:
Contact:
Ill get to try the theory tomorrow morning.
Ill head out of the house 20 minutes earlier than normal and power off at the wall , leave connected and return to it 10 minutes before I need to set off, and hopefully it will start. From memory it tends to be find on a Wednesday ( after I last use it on a Monday and put it on trickle ) but fails on a Monday morning after typically last using it on a Saturday , or even Wednesday evening.
tlracer
Reactions:
Ah, so it doesn't like Mondays...is there a Mr Geldof in the previous owners list?
andybond
Site Admin
Reactions:
Contact:
andybond
Site Admin
Reactions:
Contact:
Turned trickle charger off at 0810. Attempted a start at 0820
Fired first time
Car will be on charge again this evening until possibly Saturday or even Monday. Will review.
tlracer
Reactions:
Result? Luck? Wednesday effect? :?
andybond
Site Admin
Reactions:
Contact:
Strange one isnt it ?
tlracer
Reactions:
Odd...but then it is a Lotus! Let's see what happens with another few repeats of same, with different days :crazy:
winthattt
Reactions:
I doubt it’s anything to do with the charger., it can only deliver an amp or so and battery produces over 100 to crank the car. The lighter socket is always live so the charger will be held at the voltage of the battery which will win the voltage fight.
Let’s see, hopefully you have a fix but I don’t understand it.
