Inlet charge temps
Topics specific to owners of the series 2 Exige
frank
Contact:
Re: Inlet charge temps
Post by frank »
All this talk about intercoolers is so last year, what you guys should be talkin about is a dual fuel system that doesn't care if your OE intercooler is a toaster since you can have any detonation preventing octane fuel rating you like....Adding the proper mix of isopropyl alcohol with its 118 octane rating means the engine will not knock and you will have all the power you dialed in [boost/timing]....
At 26 psi. I make 560 whp = 644 BHP on 91 octane pump gas with my staged alcohol fuel system... :D
jfk
Post by jfk »
Dual fuel ??
Us Bits ain't got the hang of one fuel yet !!
Burstner/Ducato Motorhome
moomin
Post by moomin »
Ace ! I could use some of the local vodka the Polish are making thats cheaper a gallon than petrol .
frank
Contact:
Post by frank »
Ok so I can make 425 whp with my chargecooler setup on 91 octane pump gas at 20 psi., so what's the problem here ?
Renton
Post by Renton »
[quote=frank]Ok so I can make 425 whp with my chargecooler setup on 91 octane pump gas at 20 psi., so what's the problem here ? [/quote]
Frank, I've got a 400bhp pump-fueled, chargecooled Exige too. But coming on this thread willy-waving and saying "my car's great so what's the problem?" isn't exactly helpful or relevant.
The problem is that supercharged S2s come with intercoolers. This thread appears to be a discussion on how ineffective they are (on a hot day under track driving conditions) and how they might be able to be improved without spending the high premiums commanded by the sellers of chargecooler conversions...
I've just ordered the various parts required to carry out a couple of 'jfk' auxiliary air supplies on my friend's 2008 S. I look forward to seeing exactly what the results are and he's crossing his fingers that the extra air supply will allow the car to be tracked with the roof off.
As Buzz Armstrong once said, watch this space ;)
ade
Been thanked: 8 times
Post by ade »
What this does make me wonder is how bad a standard S without the extended scoop must be especially if you have a gotham or CN 260 upgrade :o
moomin
Post by moomin »
[quote=Renton][quote=frank]Ok so I can make 425 whp with my chargecooler setup on 91 octane pump gas at 20 psi., so what's the problem here ? [/quote]
As Buzz Armstrong once said, watch this space ;) [/quote]
To be fair the charge cooler didn't do that well either and temps are way higher than I would have thought , we need to get all the options together for a test one day .
frank
Contact:
Post by frank »
The problem is you guys are using a poor chargecooler design....
To the new guy, It's to big to wave and I've been doing big power 2ZZ powered Lotus longer than anyone.... :D
Instead of pointing out my huge man unit you should have asked how did you do it.
moomin
Post by moomin »
What sort of temps do you get on a hot day with your charge cooler ?
frank
Contact:
Post by frank »
It's always hot here in Southern California...
I'm always between 10-15*f above ambient even when it's 105*f. and I'm running 30 psi. of boost in the twisties.... That's 2nd/3rd gear high RPM driving at speeds between 40-120 mph, so the cooling effect of the airflow on the heat exchangers is key to the chargecoolers efficiency... "Heat Exchangers", that's right I run four seperate radiators and a 20 gpm water pump... My chargecooler is rated at 850 hp..
My engine water temps matain a nice 175-185*f while on the loud peddle.
