Drive shaft noises?
MrBean
Drive shaft noises?
Post by MrBean » Mon Sep 12, 2016 8:52 am
What are the symptoms of driveshaft problems .?
I've got clicking and grinding on sharp RH turns
Thought it was pads but anti-rattle springs fitted.?????? :?
Adventure not Dementia
Mr Pesky
Re: Drive shaft noises?
Post by Mr Pesky » Mon Sep 12, 2016 10:20 am
Clive
Check ALL the balance weights on the rear wheel - sometimes they are stuck onto the inside of the rim & can catch the tip of the bolt on bottom of wishbone as the wheel rotates.
MrBean
Post by MrBean » Mon Sep 12, 2016 11:58 am
Ah will do Rob ta
MrBean
Post by MrBean » Mon Sep 12, 2016 6:03 pm
Just checked. And its not that..... :(
SeanB
Post by SeanB » Fri Sep 16, 2016 2:01 pm
try gently resting your foot on the brake while making the noise, it it goes away its brake related, if it doesn't then it isn't
Drive shafts are a case of grabbing hold of the shaft by the joint and seeing how much play there is in it.
MrBean
Post by MrBean » Fri Sep 16, 2016 6:11 pm
Will give it a try.....any excuse for a blat
Thanks
