So; build me an engine
Rob999
Been thanked: 3 times
Post by Rob999 »
Looking towards this Winter it may be decision time on what to do engine wise for the S1.
The current modded vhpd is showing signs of tiredness and I must admit the lure of the Honda is proving hard to ignore...
Importantly I have to drive one first but my initial thoughts are to build an awesome NA Honda. Question is, can you build a 280bhp+ K20 without it becoming a race engine begging for a rebuild every 20k miles?
I've read up a little and doubt I want to do the Frankenstein k24 bottom end route etc...
So educate me .Com, 280bhp + reliability = realistic dream?
Feel free to air those views, I know very little! :D
#195
Benja
Re: So; build me an engine
Post by Benja »
Dan @ HPE seems to be the man of the moment for high-power NA Honda.
I can see the attraction Rob but a couple of things to consider :
- consider doing it incrementally. Just putting a standard engine with a decent exhaust+RBC manifold will make good power and be very reliable.
- you'll notice a big change in performance and power delivery with the above.
- try and pax with IDG or DaveP in their NA Hondas - it really is a sweet spot in reality.
- obviously experience a full-fat SC+CC Honda too. They are epic but are defo more expensive to run. If big power is what you want they do represent the most cost -effective proven way of getting there.
Post by Muu »
So I'm a mere tinkerer, gladly bow to the knowledge of the guys that do it day in and out. Here is my 2c though:
So if you keep to bolt on mods, drop in cams & springs, the better OE inlets, decent OTT exhaust, and user hondata I'd say you'd peg out at 250.
Frank setups might well add torque but really you're robbing Peter to pay Paul as their stroke to rod ratio means the peak piston speeds are a problem, they really hold back the ability to rev. Show me a European 'frank' doing the numbers....
Next step up, built engines etc and ITBs means ideally you want alpha-n mapping. Hondata can do it, badly. So if your plan is beyond 250 then go for a proper ecu early doors. Decent ECU and top end injectors will give you back a stable idle. You'll also want to rev, so the stock oil pump needs to go, ideally dry sumped. Here a 2.2 crank is a nice addition.
In an ideal world you'd use a k24 block that's taller with longer rods, then destroke it with a shorter throw crank. Dan Webster is your man here.
Now here is the curve ball, what about a duratec from uncle Steve? You get a nice box fresh 2.3, aftermarket ecu as stock as well as ITBs. He keeps the OE gearbox and shafts, so you side step those issues.
Plus Burton power can supply you with a crate engine with whatever power you like. The cosworth dry sump is also fantastic, no external belt and only two hoses.
Post by Muu »
Rob999
Post by Rob999 »
Thanks again guys, and an apology. I obviously have a very short memory and was banging on about this in January so I'll hush up now!
#195
Post by Muu »
No worries at all, gave me something to muse and google on the train into work
NA engines are very cool, but deffo a rich mans game compared to a blower on a junkyard engine
Rob999
Post by Rob999 »
True Tim, having driven turbo'd and NA cars and been out in SC'd loti I think I've always been an NA kinda guy.
I've already started talking to Dan at HPE and will see where this goes......
Enjoyed reading up on the Cosworth link you posted, now that would be cool to have that engine staring back at you...!
#195
Benja
Post by Benja »
Rob999 wrote: Enjoyed reading up on the Cosworth link you posted, now that would be cool to have that engine staring back at you...!
I found this S/H 280bhp Duratec, OK its more expensive than the crate engine but it comes with a Sadev sequential and well,...a free car :cool:
280bhp Duratec for sale
SeanB
Post by SeanB »
Wow, that looks tasty. You're gonna need to scratch that itch soon mate!!
