NA Honda K20 not idling right
Honda, Audi, Duratec engined variants
IDG
Re: NA Honda K20 not idling right
Post by IDG »
OK then, let me try and add some more value for the less confident (like me)...
Here's the top of the TB before unplugging. As Tim says above, there's 4 plugs (2 on top, shown here), the 3rd is round the back (you can just see the blue lead below the black plug at the top) pointing diagonally down, the 4th I didn't even bother with until I'd taken the TB off, it was just too hard to get to. You also need to remove the throttle cable. Initially I pulled the throttle open which gave enough slack to unhooked the cable off the guide (as seen right at the bottom of the pic below) and remove the TB which then made it easier to get the end of the cable out of the TB, as well as remove the cable guide from (black) bracket on the TB...
So I got it off! Moving the airbox hose more fully helped...
You can (just about) see the 4 connectors here. Also note the '4 bolts' are actually 2 bolts and 2 nuts and the potential to lose particularly those nuts down the engine bay is quite significant (wish me luck getting them back on without loss)...
Now, I whipped that little IACV blighter off the bottom of the TB; thankfully somebody had previously 'Dremel-ed' a straight cut across the two 5-point star screw heads (not even 6-point torx!) to make this easier...
There you go, pretty yucky in there. As you can see (thankfully!) the seal held together, which is good because the local Honda parts dept were useless and I hadn't found the part number on the Web.
To be able to spin the shaft in the IACV take the black sensor off the end and note the little metal tab at the end of the shaft (that you see when removing the sensor) sits at the top (the open side) for when you put it back on.
Right then, time for a clean up!
I've read that petrol, WD40 and (from the ether) various other chemicals are suggestions so feel free to suggest the rights/wrongs and I'll let you know how it turns out.
Cheers, Ian :)
SeanB
Post by SeanB »
Carb cleaner or petrol.
thommo
Has thanked: 1 time
Been thanked: 18 times
Post by thommo »
I'm impressed. Keep up the good work!
raw
Post by raw »
New gasket to hand is good tip
IDG
Post by IDG »
Cleaned up nice(ish)...
It wasn't quite as smooth as I'd have liked. If you held it vertically by the shaft and spun the body it'd spin about 360o, which is probably about 3x before but still not uber loose. I decided to reinstall it anyway.
It worked. :)
Well, reasonably well. Sits at about 1300rpm once warm and bounces down to 900 briefly every minute or so. Are others like that?
Gasket was a good idea but I reused the one on there as it held together when coming off.
Now, my problem. I struggled to get the front bottom nut on. I ended up dropping it down the back and heard it land on the undertray. I'm not worried about it causing any issues down there and expect it to fly out in the not to distant future, however, a few queries about the missing nut (for me and the others that follow)...
Would you drive it with a nut missing?
What type/size/material is that nut?
Where to get one?
How do you fit it?!
More than happy to receive material and assistance at Anglesey if it's safe to get that far.
Cheers, Ian
Muu
Been thanked: 1 time
Post by Muu »
Swap to a cap head, and from memory it's just a plane old M4 or M5, will check for you as my (spare) one is in bits
Benja
Post by Benja »
I must say I'm very impressed Ian...I'll be more impressed when we make it to Anglesey :grin:
SeanB
Post by SeanB »
No Ian, don't run it without a nut on. There are four fixings for a reason. I know you Honda boys love chopping mounts off your gearboxes and crazy stuff like that, but these things are there for a reason.
Get yourself another nut, I would use a nyloc one. Put the nut in your socket, you can stick it there by doubling over a bit of sticky tape and putting that in the socket first. Then put a small extension bar in the socket and use it like a screwdriver to get your nut started. That's what i do when access is tricky.
SeanB
Post by SeanB »
Like Ben, I am impressed you knew how to open the engine cover, let alone get as far along with the job as you have. Well done matey!!
IDG
Post by IDG »
Muu wrote:Swap to a cap head, and from memory it's just a plane old M4 or M5, will check for you as my (spare) one is in bits
Ta
But what do you mean by "cap head" in reference to helping to reattach it in its tricky location? I was thinking of something along the lines of lining a socket with a bit of blutac to help keep it from falling out whilst I got it seated on the thread.
Cheers, Ian
