NA Honda K20 not idling right
Honda, Audi, Duratec engined variants
IDG
Post by IDG »
Hi,
Started the car for the first time in a little while and it began to warm up at revs 1000-1200rpm, but after about 5mins went to 2000rpm and a couple of minutes later started to bounce between 1000-2000rpm every couple of seconds quite rhythmically. It drives ok but as soon as you go back to idle it does it.
Any ideas?
Cheers, Ian :eh:
Benja
Been thanked: 1 time
Re: NA Honda K20 not idling right
Post by Benja »
I had similar once and it was a vacuum leak - perished hose check all those first.
AndyD
Post by AndyD »
Benja wrote:I had similar once and it was a vacuum leak - perished hose check all those first.
Yup, hose or manifold leak can also be the IACV is getting stuck - unfortunately it still exists even on the Honda - easier to access though as its part of the throttle body.
Benja
Post by Benja »
Yeah I've had both a cracked manifold and a perished hose. When it did that hunting idle thing JDS fixed it I'll have to look through my old emails...
IDG
Post by IDG »
Cheers chaps.
Sounds like it needs a visit somewhere. :(
Any concerns driving it?
Benja
Post by Benja »
Nah I drove mine back from Bedford and then to Dudley. I did feel like a twat driving through London as every time I stopped it was rev'ing between 1k-3k revs like a reet boy racer!
raw
Post by raw »
Used to have same issue with mine after sitting over winter
Would try cleaning IACV
Is simple enough
IDG
Post by IDG »
Ta
You give me hope
Muu
Post by Muu »
yeah take the TB off, and then clean the IACV mounted on the bottom out with carb cleaner or solvent etc (petrol if need be).
IDG
Post by IDG »
Hi, been Googling the IACV cleaning and there's a suggestion that before I do this I can test if it's the problem by putting my finger over a hole in the throttle body. That sounds like a useful time saving test. But where's the hole (that's not Googling so well) and any tricks of what not to touch when the engine is running (eg. I and the butterfly will be moving with the surging)?
Cheers, Ian
