electrictrickery
Honda, Audi, Duratec engined variants
Muu
Been thanked: 1 time
Re: electrictrickery
Post by Muu »
two things, burning out fuel pump relays (sound familiar?) and yes pulled thread on box
Benja
Post by Benja »
Muu wrote:burning out fuel pump relays (sound familiar?)
Matt's doing some rewiring today, so hopefully that will be put to bed. I've not used it as a catalyst to commission a whole new loom ;)
Muu
Post by Muu »
TBH you could buy an off the shelf one that'd be pretty good, with the MIL bulkhead etc
Benja
Post by Benja »
Yeah the time to do that would have been when Matt rebuilt the car 18months ago, apart from a few tidy-up jobs the wiring was barely touched.
Muu
Post by Muu »
being brutally honest, wiring is a time (and therefore invoices) sink hole especially for people where it's not their bread and butter
see what some easy clean up can do and take it from there
SeanB
Post by SeanB »
Wiring can be a nightmare if old and has been added to / take away from over the years. Eventually biting the bullet and getting a proper one made up is the way to go.
SeanB
Post by SeanB »
When I was racing I had all kinds of weird electrical gremlins, one of them turned the boost up every time i flashed the headlights. I don't know how that happened. ;)
Muu
Post by Muu »
right busy day:
so cracking on with the main wiring plate:
that's now done:
and installed:
here is the MIL bulkhead connector
I didn't have the correct crimp tool, it wouldn't go shallow enough so I improvised by stacking a pair:
So engine loom hands off to chassis here:
Also put the IACV and TPS on a 8 pin DTM so I can swap to DBW if required and just a small rewire cabin side:
have also put a expander connector in place should we need to add anything:
Oil and forgot to post this, remote oil pressure sensor:
Fuel pressure sensor:
Need to get this mounted next:
Benja
Post by Benja »
Wow Tim. I'm sure there quite a few proper competiton cars out there that the workmanship in that wiring would embarrass.
Final push bud,..let's see the car out to play next week...
Muu
Post by Muu »
yeah head down, and hopefully you'll see it at parc menai
