electrictrickery
Honda, Audi, Duratec engined variants
Muu
Been thanked: 1 time
Re: electrictrickery
Post by Muu »
so yeah I have the Dash2Pro with the DL built in, so will feed an analogue in with the PLX and use it's narrow out for the Hondata.
Trying to capture all the wiring changes into one design, so I've allowed for future changes etc.
Muu
Post by Muu »
more bits of loom made up - The bit that goes over the head:
Put the crank sensor on it's own breakout, so I can really seal that connector as it's a pain for getting water in.
Need to do throttle sub-loom, chassis pickup loom, gearbox breakout loom and then bring it all together again to the MIL
Muu
Post by Muu »
clam off with the help of Mrs Muu:
time to tackle this OE mess:
strip it back:
took engine out to get at the box
DaveP
Post by DaveP »
Blimey - you've been busy !!
ade
Been thanked: 8 times
Post by ade »
Not long till Easter ;)
Muu
Post by Muu »
I'll be all good (famous last words)
The Cable Guy
Post by The Cable Guy »
http://uk.farnell.com/thomas-betts/tc10 ... dp/1996540
this is what we generally use for zip/cable tie bases, bonded wtih RT125, as its generally done to raw CF so doesnt have a perfectly smooth surface.
cracking job, nice to see your using proper bits i.e DR
The Cable Guy
muu.
is this what you've used for the battery connection?
http://www.polevolt.co.uk/acatalog/info_MIDI1.html
quite like that idea of fitting it on the bulkhead, as i refuse to spend £120 on a autosport panel mount battery connector.
Muu
Post by Muu »
yeah got two of them on the bulkhead, one with the starter on, the other the alternator.
They then swing around to a carbon panel with a 2 pole binding post.
ps polevolt are great - amazing how it all adds up though.
Muu
Post by Muu »
ok may as well use this as my build thread until I get my threads merged (one day!)
While the engine was out gave it a quick clean up, and replaced the knackered red hose with a wire reinforced black one:
and wanged a new clutch OEM in:
and while I was feeling flush ordered this to combat any understeer the diff brings
but anyway back to wiring, this will be my new chassis plate where the engine loom meets the car (on Duetch DT)
the engine loom will go via a MIL connector on the bulkhead:
and will be wired back to this point:
