Electronics guru needed
Keep in touch with fellow enthusiasts.
lotuslee
Hi Dave yes it does, rev counter first to about half way then speedo to half way.
Like i say everything else works perfect includding abs light not illuminated
lotuslee
Well i plugged the TC switch in and yes its no better 😪😪
The fact the ABS light is off would sudgest the speed sensor is working.
Any hints on what to check next ? ABS controller ? ECU? Stack unit ?
andybond
Site Admin
Contact:
Go backwards - not literally.
Can you set everything back up how it was last working?
lotuslee
No not really i think i need a can of petrol though
thommo
lotuslee wrote: Tue Jan 19, 2021 9:09 pm No not really i think i need a can of petrol though
:lol:
series_one
Call a dealer or specialist. There was a reset process that involved the door opened (really) and turning the key to pos I or II and pressing the milage reset button or something similar. That reset the ecu settings AFAIR.
ade
have you tried to disconnect the battery for 24 hours to allow everything to reset if it can
lotuslee
Thankyou to all the help and advice, i have finally found the issue after a few nights of checking and tracing wires.
It turned out the fuse box, fuse holder had corroded up so only 11.6 Volts getting to the ABS unit. Once replaced the terminals all is now well.
Thanks again no can of petrol needed.
andybond
Site Admin
Contact:
I was about to make an essential trip to the North West with a can of petrol and matches as well.
Glad its sorted Lee!
Fonzey
lotuslee wrote: Thu Jan 21, 2021 10:13 pm Thankyou to all the help and advice, i have finally found the issue after a few nights of checking and tracing wires.
Great work, annoying issue but no harm done in the end. Result :thumbup:
It's funny how taking a car apart and rebuilding can uncover these types of issue.
