After fitting 4 new wheel speed sensors my speedo will not work the ABS light was illuminated but went out once driven and no fault codes.
Everything on the instrument panel works as it should just no speedo.
I have double checked all the hub sensors and they work as they should.
The car has variable slip traction control fitted but the traction control button on the centre console is not plugged in (console away at trimmers)
Anyway would this button not plugged in stop the speedo from working and the speedo getting a signal.
Checked all fuses etc and wires going into the instrument panel and all appear ok.
This is a 2010 black dash car.
