Removing track rubber from armourfend
Keep in touch with fellow enthusiasts.
Boothy
Reactions:
Any tips? I can remove it from the paint no problem with auto glym tar or bug remover but its seriously stuck to my armourfend.
fatcat
Reactions:
No idea, however when my (ex)S2 was serviced at Sinclaires the car always came back with the Armourfend as 'new' (ish).
I think a mixture of tar/bug remover + a hot jet/pressure washer may have been used.
Reactions:
Autoglym tar remover works for me! :cool:
R300
Boothy
Reactions:
Hmmmm, Autoglym tar remover has always worked in the past for me but not it only works on my paint and not the armourfend...
I wonder if a scratch remover will work on it?
21TonyK
Reactions:
WD-40 works well unless the Armourfend takes the paint off...
pete757
Reactions:
[quote=Boothy]Any tips? I can remove it from the paint no problem with auto glym tar or bug remover but its seriously stuck to my armourfend. [/quote]
AutoGlym paint cleaner mate. Works perfectly! :)
But leave it till after MOnday eh!!! :grin:
Boothy
Reactions:
[quote=pete757][quote=Boothy]Any tips? I can remove it from the paint no problem with auto glym tar or bug remover but its seriously stuck to my armourfend. [/quote]
Which one is the paint cleaner mate? Not seen that, a search on google showed a paint renovator which I think I own somewhere :grin:
Don't worry I wont be doing it till after monday? ;)
jfk
Reactions:
Are you sure it's just stuck to the armourfend ?
What I mean is ... what looks like stuck rubber and tar may actually be under the surface of the armourfend cos it's got stone chips in etc.etc. This was the case with mine ...
Had to remove it to make it look ok again ..
Burstner/Ducato Motorhome
TonyKL
Reactions:
I've had this problem too, I found that a de-greaser worked ok but I still have marks along my white sills :( mild clay would do it but would take forever.
I was also shown that Autoglyms super resin polish will actually remove the rubber too !
ade
Reactions:
I use T-Cut to get it off mine,seem to work ok and it's cheap ;)
