WTD:- A Set of 440cc Toyota Injectors
Not sure if they are the correct ones for 260 upgrade
But as said they are Green and have Denso BAF.2 stamped on the side.
They were OEM on my 240pp car
£150 for all 4 posted to a UK address
Fuel pump…I’d speak to Dave at Seriously Lotus
They will be fine for the 260 upgrade, Sinclaires run bigger injectors with the Gotham tune
Thanks for confirming Ade :clap:
Just the highflow fuel pump to source now, any bright ideas? :slight_smile:
Are you sure you need a bigger fuel pump??
Mines OEM with the Gotham tune Sinclairs did.
Or maybe mine was bigger to start with as my car was 240pp??
The 240 pump is the same as on my 220, but Lotus recommend the uprated fuel pump, not sure I want to risk it?
No idea what others have experienced.
Taken from the Lotus Silverstone website
WARNING Whilst it is possible to achieve the higher performance figures with the standard fuel pump, it could lead to the engine getting starved of fuel at full throttle which would have negative consequences.
http://www.lotussilverstone.co.uk/service/view/77/Lotus-Exige-S-260bhp-Upgrade
That was my understanding to at WOT there could be issues.
I have the standard pump on my 240PP with over 270hp EA Gotham tune , never had a problem , it’s on my to do list though .
when I upgraded my 240PP to 260 back at Hethel the upgraded pump was necessary.
I have purchased a brand new denso pump and fitting kit from a guy on seloc :slight_smile:
