[quote=Mark_A]If you have relatively soft spring rates, i.e. 400/475lbs then fitting a 2.25x stiffer bar will have a much bigger effect on roll stiffness balance that fitting the same bar on a car with 550/750 springs.
So anyone looking at ARB’s need’s to look at the whole set-up otherwise they could end up screwing up the handling balance.[/quote]
makes a lot of sense. is there a reference anywhere that matches ARB stiffness to spring rates ?
i have the lotus adjustable ARB on full stiff all the time and there’s a lot of wallowing going on. i have the one-way nitron standard rate eibach springs. i think that’s something like 425/550 but i can’t remember off the top of my head.
i’d like to know if the eliseparts 1" as currently stocked would be overkill ? i’m pretty happy with the spring rates i have as the car gets used on the road a fair bit and it’s working quite well for that.
