Toyota R888 pressures
SeanB - What tyre pressures do you guys recommend? :slight_smile:
Just to be clear…
On the road I run 25psi all round, all day, everyday (it’s not actually out everyday but you get me).
At a track I drop to 21psi all round. Upon leaving the track I’ll pop in about 2psi and make up the difference to 25psi when I do a post TD clean and inspection a few days later.
22/24 was with the Audi in the back, so slightly more weight
I could tell ya…
Loved the tyres! Final run was 20 front & 22 rear. Wanted to try 20 all round but my suspension went - that’ll be next time out, then.
Thanks all,
Mark
Thanks for post Mark. Never got to try various pressures as you know but it’s an interesting topic. Let us know what you decide on suspension as my ā€œclassicā€ set up can’t last forever!
Wish I’d put a bit more air in for the way home, they tramline quite a lot on the road at those pressures. :crazy:
Kept me awake though!
[quote=Podger]As a tyre gets hotter the pressure increases, this is due to the moisture in the air.
Statement here seems wrong to me - heat any gas and it will increase pressure irrespective of ā€œmoistureā€.
[quote=stevegreen][quote=Podger]As a tyre gets hotter the pressure increases, this is due to the moisture in the air.
Statement here seems wrong to me - heat any gas and it will increase pressure irrespective of ā€œmoistureā€. [/quote]
If you have a problem with his statement phone Alan Meaker
01933 41453
supplied in his email ( and shown in the earlier part of this subject)
