sorting VHPD drivability issues
Hey Klaus, I’m replacing all the vacuum hoses and t-pieces, I wonder do you recall the bore size of the hoses?! I’m nowhere near the Lotus and would like to order them if someone has the knowledge of the correct bore size that would be great so I can get them ordered in time for getting them installed Friday, cheers! :slight_smile:
Pretty sure it’s 4mm internal diameter, I replaced mine a while back with silicone hose from these guys:
https://www.advancedfluidsolutions.co.uk/ - Product code was BVAC-004 for black or RVAC-004 for the red stuff (cos I fancied a bit of bling to match the HT leads and catch tank hose) :smiley:
You need to get some Brasso on the throttle cable elbow :smiley:
If I remember right I did use 4 mm and 3 mm hose. I think I used the smaller hose for the short piece from the T-connectors to the manifold outlets. The outlets are pretty small and one of the four were even not properly fixed on my car. Another potential air leak.
I would just order both 3 mm and 4 mm hoses and see what fits best. It’s not too expensive and there is nothing more annoying if you miss a cheap part while working on the car on the weekend.
:laughing: Ha ha, I thought the bay was looking quite tidy but you’re right, I missed a bit :blush: :laughing:
Awesome chaps, thank you for the info and links :slight_smile:
Check the T-connectors as well when you’re replacing the hose. I found a couple of mine had gone very brittle so replaced those as well whilst it was all apart.
Indeed that is what prompted full replacement as i was checking the t-piece connectors one of them snapped so a full set ordered plus extra just in case!
:smiley: sorry
I bought my black hose and connectors off eBay. Same for the washer bottle.
So by way of update I have resolved my running issues were mainly a rich running condition.
Vac lines replaced and t-pieces, coolant temperature sensor and air temperature sensor. Result, seemed to be slightly improved but in reality still very rich.
Next step was to go with a hunch and treat the car to a 2bular cat back system as on an oil service there was clearly a leak from the back box. Turned out the flexi was caput and snapped off. So new flexi welded in along with 2bular system and she runs real sweet again. Exhaust emissions I haven’t tested but for sure the richness is away. So anyone struggling with a running rich issue could be what appears to be a rather minor leak from the exhaust at the flexi (I guess the backbox leak wouldn’t have affected the emissions quite so much).
Glad you got it sorted and amazed you were able to get a 2Bular system…
…when I ordered one I put up with months of missed completion dates, excuses and finally told that S1 systems were no longer available ( indeed they only returned to the catalogue recently ).
Anyway well done and enjoy the car!
That’s great news. As I added on my Exiges day post…my vhpd went mad popping, banging and very rich just before the Anglesey Exiges day. I fitted some new Ht leads and it has never run sweeter. It’s always been good (after I replaced the lambda sensor) but now pulls 30mph in 5th.
Excellent chaps, they are sweet when running properly :sunglasses:
Pottering along with no hesitation just blip through the gears effortlessly, like a different car it is and the mid range pull up to 5k is almost disturbing. But on my test drive I noticed a strong fuel smell when pulling up at a junction. Not the running rich smell but neat fuel smell - I suspect the fuel cap seal as when I released it there was some petrol sitting in the top of the filler recess and it didn’t seem to hiss with pressure release when I took it off. Replacement seal if I can find what size is needed next! Perhaps also the fuel breather hoses but cap seal first I think
Good news that you finally found the reason for the rich running, thanks for sharing :thumbup:
What do you think, how did the exhaust leak messed up the mixture? Could be that the missing back pressure had an influence on the MAP values or maybe some air has been sucked in to the exhaust system and corrupted the lambda readings.
Has the fixed leak had any influence on the idle MAP readings?
Keith, what brand of HT leads did you use?
The Exige is able to run properly with the original ECU. But the MAP based load calculation principle is very, very sensibel to all sorts of faults.
I had the opportunity to swap cars with a fellow German Exige S1 owner whose car had been switched to an Emerald system. He was surprised by the smooth running engine on my car and said he would have never switched to an Emerald if his own car had been running like mine.
The most noticeable thing for me on his car was the better mid range torque.
I still got those small hesitations below 3000 rpm but maybe I’m just to sensitive.
Klaus,
Magnecor red leads from Geary. Mine must have been faulty for a while as it really is better than ever. Since then I have also disconnected the catch can and refitted tge re-circulation of breather gasses, the catch can never caught much, just water from cold starts. Car is much less smelly now, I’ll refit for track days.
Keith
I must plug in the OBD reader again and take a look at readings for MAP and fuel trim, will be interesting to see. I will try to post up a photo of the removed exhaust system, but yes back pressure must have been so low with all the baffling burnt out of the OE system AND two big holes! Perhaps the flexi section leaking which is right next to the lambda had a larger impact on the mixture.
I would always step out of my car with that ‘Exige’ odour, my jumper would retain that motorsport race day smell, now, none, just doesn’t smell at all.
My car also feels like there is a fatter torque curve in the delivery, it was starting to feel like a 2 stroke, all top end and little in the middle. Now really quite civilised too with pottering possible though there is still the occasional though not often hesitation when going real slow in town say in 4th at 30mph.
If that’s the OEM exhaust it is amazingly heavy. I had a new spare which I chucked in the skip.
Yep that was the OEM bit of kit, 2Bular on the car now which I like a lot although I do slightly miss that hornet’s nest zing that the old system had however I now have a lovely burble sound.
Another update for info purposes, as trackrod suspected my MAP reading now has also similarly dropped from around 68-69KPa to 61-62kPa.
Good to hear that the idle MAP value finally dropped to a similar value like on my Exige after the fix. So it looks like that checking the idle MAP value gives a valuable first indication if there is something wrong in the induction/exhaust system.
I think it was ‘thommo’ who reported that when he fitted a decat pipe to his S1 (which runs the original ECU) the drivability got worse. Looks like that the exhaust back pressure has got some influence on the MAP readings.
Klaus
