So what you are actually saying Simon is that your views are right and everyone else including the likes of DVA, Auto-Teknix, Scholar, Minister, PTP and many many others are wrong or do not have the full facts or can’t build engines properly.
Yet why dont we see Simon Erland engines being advertised and raved on about ? - I’m sure with a bit or a lot of cash injection you could put the rest out of business and completly take over the market in building K Series race engines!
I don’t get why you think the Rover has so much more torque than the Honda. If you look at the results below from a group test of loads of Elises with different engines you will see that the Hondas produce more torque than the Rovers happily (obviously Bernards car kicks everyones arse comprehensively). They are also in a different league in terms of drivability which counts more than torque and horsepower out of the bends. Worth much more than the extra 10kg the Honda gives you. All this variable cam stuff really works and gives great results.
I guess what he means that the spread of torque.
A longer stroke engine would have the benefit of greater low and mid range torque. And if built properly, make some good top en power too.
Limited only by the piston velocities, but that should be ok up to about 8500 rpm, which is good enough for me.
In this case you wouldn’t need to keep constantly shifting gears to keep the engine on the sweet spot, because the sweet spot would be massive.
It’s not all about peak HP, but delivery. I would go as far as integrating the area below the torque curve. The more it approaches a square (and the higher the square is) the more power available to put on the road.
In fact, when Russ (who I consider a good driver) gave me some pax laps on his Honda Exige, I noticed how much he needed to shift gears to keep it on the boil.
And although his straight line acceleration was greater, I was able to keep up with my VHPD car.
I would say, if you need to use an engine that requires that sort of shifting action, you need to go sequential, otherwise the time you lose shifting can’t be compensated with power.
This is, apart from the power quality. This is why Ducatis win more than any 4 cyl bike. Not only torque spread, but what it does to the feeling coming out of a turn. (erm, sorry for the analogy, but I used to race bikes)
I agree the Hondas, like most Jap engines, are all revs and the long stroke of the K should give a good spread of torque. You are getting into F1 piston speeds though at 8500 rpm. I can see why you opted for low friction liners. Aren’t they mega expensive though ?
Simon, have you got some power curves for the engines you’ve built ? Be interesting to see them.
The other thing with the dukes and suzuki have developed something similar with a 4 cyl is the power is always slightly interuppted so the dukes effectivly have inbuilt traction control (especially when there’s 250bhp going through a square inch of rubber )… But Suzuki have made a 4 cyl which fires 2 pistons at the same time so is like a double Duke V-Twin.
I really think it is time that a few of us got together and had a group test. It would be bloody good fun and very very informative for anyone considering mods or and engine swap. LETS GO TO BRUNTINGTHORPE!!
I took my folks Shogun around the 4*4 course a few years ago and it was brilliant fun. Thought I was going to drown it at one point as one of the water splashes was more like a lake and I ended up with water up to the windscreen!! Great fun.
