This is only a problem if you are running out of oil, i.e. below minimum…
I note your location is Hampshire so unless you are going to drive approx 120 miles north you should be ok, in fact so long as all of you steer clear of leicestershire then you should all be ok!!
Thanks Steve. Although my wife tried to wind me up by suggesting your location could actually be a typo for ‘North Hants’ and I could be using the very same outlet!
