Can’t have enough light, the more the merrier. At least 2 circuits.
Bear in mind you may at a later date start hanging things from the ceiling
I have two 6ft LED battens (daylight, so around 6000K) and those are absolutely fine, with floor area around 36 sq. m. That’s downstairs so the Velux don’t come into it, other than down the stairwell at one end.
Prior to that I had two 6ft fluorescent twin strips, and the LED’s knocked those into the proverbial cocked hat…much more and it would look like the teleporter off Star Trek!!
Thanks for your input gents, much appreciated.
I’ve done some calculations and more research, apologies in advance for the dull post
My other outbuildings have 2x 5ft LED battens (5,600 LM each @ 4000k/daylight), providing a total 11,200 Lumens (LM) in each room:
Outbuilding 1 - Low Ceiling 2.2m
11,200 LM / 150 sq. ft = 75 LM per sq. ft (Adequate light)
Outbuilding 2 - Low Ceiling 2.2m
11,200 LM / 250 sq. ft = 45 LM per sq. ft (Not enough light)
Based on the above and searching online suggests a workshop needs somewhere between 70 LM and 100 LM per sq. ft.
New Garage - High Ceiling 3.7m
43,200 LM (12x 600x600 LED Panels@ 3,600 LM each) / 515 sq. ft = 84 LM per sq. ft (Required min. light?)
The design will probably have three separate lighting circuits; 4x panels above the work-bench/back-wall and 4x panels above each bay (2x panels either side of each car to prevent shadows):
Been a while, just thought I’d post an update!
Almost got the exterior complete, just needs guttering, drainage/attenuation tank and driveway sorted:
Interior first fix is done, just putting the finishing touches on hold due to starting on the house extension before winter kicks in.
Couldn’t resist getting the Exige into its new home and taking a few pics last weekend, just a shame it’s not quite finished:
Looking good
Very jealous.
That looks fantastic! Well done
I have garage envy
ooooofffffff
lovely mate.
i’d be well happy with that!
Been busy working on the house, so not much progress to report on the garage. I’ve managed to install a new (to me) Automotech four-post lift, after having the posts re-powder coated to match the garage doors. Not really necessary, but I couldn’t resist!
It’s only a short bed lift (3.2m), smaller than I wanted but got it for a good price and should be perfect for working on the little S1.
Next job to wheel it across to the other side and test fit the car, just hope the jacking points align!
Fantastic! Lift looks great, I want a 4 poster next to my scissor just to cover all bases
Looks perfect.
Very similar in length to mine and that works fine.
I have a small motor bike scissor lifter as the beam jack, what you have looks better
The jacking beam wasn’t included in the advert when I bought it, as wasn’t the mobile wheel kit. In effect I got them for free! The lifts hardly been used by the previous owner, was just left behind when moving house.
At £3360 new, I thought it was a bargain at just over £1250
That looks great!
Very nice
