Given my lack of Lotus knowledge and the lack of info on the Lotus site I thought I’d ask here what spec would be best given the following requirements…
Will be tracked 1-3 times per month.
Will visit the Nordschleife 4-8 times a year.
Won’t be used as a run about unless I fancy a blatt.Given these my thoughts on spec are
Air Con required. The Europe trips will need it.
Harnesses required.
Sports exhaust.What else?
I see some have ‘Sports suspension’. What does this mean 1 or 2-way adjustment?
Are there any other desirable options? Brake upgrades?
Lastly what are the must have tweaks from std. Geo by Guglielmi?
I thought lighter seats.
Are there much aftermarket bits like a carbon fibre spoiler, better/lighter undertray etc.
Lots of questions, thanks in advance
Given all the above and your subsequent posts, it really sounds to me like you should be going for an S1 - I don’t understand your comment about leverage, can you explain a little. The only thing I could think was you were referring to the extra weight on an S2
