Lotus Elan Sprint (26R Special).SpecificationsBody Work & Interior:- 26R Wide arches front, rear and inner rear,Lightweight (shortened) 26R bumpers, Differential cooling duct and link pipe, Full Safety Devices F.I.A. Roll Cage,Driver & Passenger 3-Point Harness,Red Leather 26R Steering Wheel,Stack memory tacho & shift light,High visibility ign & oil pressure warning lights,Ignition isolator key & push button starter,Micro Dynamics Adjustable Rev limiter,Engine & Transmission:-1760cc John Smirthwaite built all steel Twin Cam producing 176BHP.Twin Weber 45 Carburettors With large Carbon Fibre air box and ITG Foam Filter,Dry sump with Remote Aluminium oil tank,5 Port oil pump,Mocol oil cooler, and oil temp sender,Remote Oil filter with low oil pressure warning and fuel pump cut out unit,Custom big bore straight through exhaust system,26R Aluminium radiator and header tank,A.P. Heavy Duty racing clutch,Close ratio Straight Cut gearbox with one-piece quick shift lever,Quafe Limited Slip Differential with aluminium Lotus strengthened housing,26R rear one piece drive shaft & hub assembly (no tapered joint), including Hardy Spicer sliding spline drive shafts,T.T.R High Torque starter motor (will not fail),Chassis, Suspension & Brakes:-Adjustable shock absorbers with adjustable height platforms & stiffened/shortened springs all round,26R Front anti-roll bar,Quick rack Steering with aluminium mounts,26R Tubular Rose jointed rear wishbones,26R Magnesium Rear up-rights,26R Girling AR Aluminium front callipers,26R discs all round, With Blue Hawk race pads,Twin line brake system with twin remote reservoirs and adjustable bias for rear, braided brake hoses throughout whole system, (Servo Removed)Other Parts:-Two sets of magnesium 26R knock-on wheels, one set fitted with new road legal Yokohama Advan 032-R Tyres, one set fitted with part worn Avon Race Tyres, also 4 brand new Avon race tyres,Electronic fuel pump with low oil pressure cut off and manual override,Aluminium foam filled fuel cell, Braided fuel hoses throughout,Aluminium firewall between fuel cell and interior,Lucas electronic ignition & sports coil,For Further Information or viewing contact Martin Edwards on:-Tel, 07973 725980, Or E-Mail:, [email protected]
