It seems like Ian has transferred his bad luck to me ! What with the shaft snapping at Outlon and then a wheel bearing yesterday - but c’est la vie as they say.
Ref choice modification, I did spend yesterday after I got home pricing a few parts up
Looks like uncle martin could be busy again !
Interesting…was it the same side wheel bearing as the shaft that went ?
Eek…that doesn’t make good reading…What happened Con ? [/quote]
Just a rear wheel bearing - obviously the meatier bearings in a motorsport rear upright would go some way to mitigating it happening again…and if you’ve gone as far as doing that then you may as well put the front calipers on the back etc etc [/quote]
Another !
This is becoming the next peice of the puzzle that fails, unfortunately its usually the crap cheese, or badly toleranced cheese drive flanges that create the problem.
Im on, I think my 5th set …
There is only 1 solution - talk to Martin/Steve and JSR >>>
After a thoroughly good day at not more than 6500 revs (truely officer)easing in my new K got home to find significant oil leak from bellhousing,??crankshaft oil seal failure after 800 miles??? PLUS oil consumption as bad as before rebuild …
anybody else suffered after a full engine upgrade??
