For a while ago I adjusted my camber …toe… At home…
I was aware that I had a big Toe out (3mm) at the front… I didn’t adjust it myself because of access. So yesterday I went to try a 4 wheel alignment machine… I was quite happy with the result there… my measured angles showed almost the same at the 4- wheel [censored] … So they adjusted the front Toe for me, Since my rear Toe was a bit out of spec, they adjusted that one as well…
SO the next day (today)… I wanted to check it myself at home… Everything was looking quite good , even the front Toe… But when I was checking the Rear Toe…Wtf… almost 3 mm toe in on LR… and a bit of Toe out at the RR…
Don’t really know how this is possible… Is it possible to use the alignment machine wrong?? Anyone experienced the same???
I’m quite pissed off right now… Can always adjust it myself, but I think Ill wait , because I want to COMPLAIN… But the problem is that I have a short track day on Sunday… And how will the car behave with my fuckked up Toe???
Just had to get it out… Feeling much better mow…
