2ZZ Built Engine
Its not a quickly job, its a properly job. I’ve got it on SORN and laid it up, so there’s no rush. Season’s nearly over, never really started for me. Just need to make sure that next year is epic to make up for it :slight_smile:
I’m sure it will be, got to get the compression checked on mine still, decided I would do it after the last 2 track days of the year :wink:
Don’t forget to check the Gayness on both your supercharges, use a good Gay-dom-meter…it should always read at MAX :smiley:
Good luck with it Will :wink:
[quote=jonnyfox]Don’t forget to check the Gayness, use a good Gay-dom-meter…it should always read the iMAX PlasmaTV :smiley:
Fixed that for you :wink:
