1800 K series liners
No Simon,
It’s just your usual blinkered intepretation. Using a coating on an ally bore does away with the need for liners. I didnt say that it was the only reason for a coating, it only requires a couple of brain cells to see the meaning, perhaps you can ask someone else to help.
I have seen plenty of coated liners and coated bores, probably before you have seen any at all.
Dave
You should read your own posts back…
simon
“The main reason for coating a block is to do away with the need for liners, lower friction is simply a by-product.”
And you post a picture of some coated liners.
http://www.google.co.uk/search?hl=en&lr=&rls=GGLJ,GGLJ:2006-12,GGLJ:en&defl=en&q=define:non+sequitur&sa=X&oi=glossary_definition&ct=title
Hmm not really too clued up about liners myself but one of my friends has this, its a 1993 V12 F1 Engine that uses air valves, which is an iron block that doesnt use liners.
[image]http://img.photobucket.com/albums/v53/quo007/DSC00298.jpg[/image]
Aaahhh, but have the bores been coated?
Sadly I think he might notice if you take the opportunity to shoe horn it into the elise you are building.
[image]> http://img.photobucket.com/albums/v53/quo007/DSC00298.jpg> [/image]
Im sure it will fit with some gentle persuasion
Come on Christian - get the first 3.5l V12 elise. You know it makes sense. Not sure what transmission you will use though.
PG1 will be fine, Rover built it don’t you know
It’s a honda box actually.
simon
that must be why the Honda engine goes
so well in the Elise, its just that Lotus used the
wrong Honda gearbox.
